Old 12-28-2018, 12:28 PM   #4
Blackroot
Originally Posted by Oldcarguy View Post
I know a sticking (on return) clutch pedal can be a symptom for slave going bad, air in lines, clutch bearing, etc. but I’ve got a slightly different manifestation.
Under normal and spirited (heel and toe) driving I have no clutch pedal issues. Smooth engagement, proper pedal travel, etc. Clutch has ~4,000 miles on it since rebuild by PO’s independent shop.
However, when braking extremely hard with the clutch disengaged simultaneously (classic ‘panic stop’) the clutch pedal returns halfway and sticks. If I depress it again, it returns normally. I discovered this because I occasionally engage the abs on purpose to exercise it. But sometimes the pedal will also stick under very heavy braking without getting into the abs. Brake and clutch pedals are firm.
I’m going to purge the brake/clutch fluid (with Motul 600) and see where I’m at. If nothing changes regarding the sticking pedal, looks like I may be headed for a clutch slave cylinder replacement next. I need this fixed before I put the car on the track for HPDE events.
Any thoughts?
The brake fluid brand/type would be interesting if that changes.
DOT 4+ is DOT4 +
The volume isn't going to change in the master or slave with new fluid.
Might want to see if the slave cylinder hard line (12mm flare wrench used only) is tight. The slave bleeder is 11mm.
Could be many things...
1. pressure plate springs are weak or failing.
2. slave cylinder is not quite right with air bubbles.
3. Bad throw out bearing or in pieces
4. Master cylinder return spring (mentioned)
Also, if you think about what you just said "when braking extremely hard with the clutch disengaged simultaneously (classic ‘panic stop’) the clutch pedal returns halfway and sticks", remember these are shared fluid systems, so the caliper might not be returning enough fluid to pull up the clutch.
Seems to point to air in the system
Blackroot is offline   Reply With Quote
