Old 12-26-2018, 06:24 PM   #4
elgyqc
elgyqc's Avatar
I'm no expert but I'd pull off the front engine cover (behind the seats, remove the upholstery/insulation piece with 4 plastic nuts on top, then the cover itself about 10 10mm nuts and bolts) and see if it is an idler bearing, an accessory bearing or the belt.
Good luck.
Grant
