Old 12-26-2018, 01:59 PM   #11
Blackroot
Okay, car was started and runs great
Couple of thing to mention-
1. Make sure your serpentine belt is back on after all the cam locking work.
2. Make sure the intake hose is on after the top bolt of the transmission was removed.
3. The whole oil pressure pre-startup cranking thing makes no sense to me. You will damage parts if the engine is rotated without it running or not. FIRE IT UP.
oil pressure will not be normal unless it is under normal running condition.
Blackroot is offline   Reply With Quote
