					Originally Posted by  thstone
				My thoughts...
If you want a street pad that will also work for the track, then I'd recommend EBC Yellow. They won't make any noise on the street but may not hold up if you are truly running front of the pack Spec Boxster lap times. They are more affordable than Pagid. They might work well if you're only doing four track days per year and the rest of the driving is on the street.
As I mentioned in my original post, I've been using EBC Yellows, but found them to be terrible on the track. When they get hot, they cause a terrible juddering at each corner. Reading of other's experiences on this forum, I know that I'm not alone in experiencing that. They seem to work okay up to 7/10ths driving, but if you go past that, no thanks.
