Hi guys !
I finally found the time to install the prototype for the L shaped lever !
It works great !
I'll drive it for a while to verify that the concept works, then the final product will be made out of aluminum with a removable insert to suit the shifter's side ball.
Here is the before/after video :
https://youtu.be/qrJdOKEiz-o
The first part of the video shows that a lot of side-to-side movement is lost in play in the L shaped lever. Second part of the video shows the prototype installed, and all the side-to-side movement being transmitted to the shift cable !
Ben.
