Cam cover oil leak is not always what it seems. Probably a plug tube, very common and much easier to deal with. As mentioned, I’d consider the WP/coolant but I would monitor for leaks before simply replacing. As far as the other items, replace as necessary. If you buy the car, get the cam cover situation nailed down, do plugs and tubes anyway and drive it till the rubber falls off.
