Folks, I installed the EBS baffle this evening, and I'm a little uneasy about the way it fit.... so I did a search and found this thread.
When I put it up in, it fit nearly tight on the rear, but had a 3/8" gap on the front. I pressed (hard) and it moved up in, but sprung back. So I put the bolts in and pulled it up evenly with them.
Now I see this thread.
Should i drop it and trim it? What could i have bent? Or is this correct? Should i leave it be?
Thanks in advance.
