Thread: Chain noise?
Old 12-20-2018, 07:32 AM   #21
Lew
So Blessed!
Lew's Avatar
Originally Posted by jvfante View Post
The clutch in making the noise go away seems to be pointing to your throw out bearing or perhaps a rattle/vibration in the release arm or spring.
As an aside, I had all sorts of fits with shifting in 1st gear making horrible vibrations until I replaced the single front engine mount. It's a cheap fix easily done in your garage.
Good to hear you pointing to the Release Bearing. Bell Housing condensation will rust a release bearing over time and it will rattle. With the Engine running clutch out it will rattle when shutting the engine down. Clutch in no rattle when shutting down the engine. DMF I doubt it's the problem.
Artic Silver Boxster S - Black Leather - Black Top - Convience Plus Package
Lew is offline   Reply With Quote
