Old 12-19-2018, 08:43 AM   #2
rick3000
There Is No Substitute.
rick3000's Avatar
I thought you could install the upper shelf where the cupholders are, however I cannot seem to find any confirmation on that from a cursory search. It would probably be easier to relocate your AC to the top position, you can then use an OEM trim piece around the top position AC, and install a shelf in any of the other three positions. Note that the lowest position cubby is different than then other two positions.
