Old 12-18-2018, 05:03 PM   #28
rick3000
There Is No Substitute.
rick3000's Avatar
Mine shows when the spoiler is deployed (solid light) and when it is going down (flashing), it does not flash when the spoiler is deployed. This is because I broke the pin that you insert into the cluster plug, which I am pretty sure is actually the end of a diode. I just accepted it and moved on, but if it bothers you, I would make sure the pins are all inserted well.
he switch has nothing to do with the indicator light, the switch only controls the actually spoiler deployment/retraction, and the switch is not even used when the spoiler deploys automatically.
