Need a little help please....solid/semi solid motor mounts???...
Hi all:
I have a supercharged 2.5L and I need to figure out a way to limit the amount of engine movement, please let me explain.
The engine got new factory mounts not too long ago but, on spirited turns and under hard acceleration, the engine will "torque clockwise and the output pipe for the SC will make contact with the right side lower suspension link, I have done all I can to minimize this but could still use a little help.
I have done a search but have not found conclusive answers.
Has anyone installed aftermarket mounts that are stiffer than factory?, did you benefit from this?, I understand vibration will migrate on to the chassis and will be felt but, Is it "that" much more?....
Any input or ideas will be greatly appreciated.
Thank You.
