Old 12-14-2018, 01:37 PM   #11
itsnotanova
Originally Posted by Anker View Post
That's so frigging cool, Woody! I'd love to do something similar. 1000lbs is HUGE!
100 thumbs up!
I think you need a locking differential.
Regards, Markus
Thanks guys. I'm hoping for a total weight of 1500-1600 lbs. I'm going to go get it weighed next week to see. I'm half tempted to throw a Lincoln locker in it. I'm too cheap for a real LSD.
I'm not sure if I'll ever get to take it to a real track, but if I do I threw on some tow hooks in case. As you can see, one is a nice manufactured tow hook specifically made for a Porsche, and the other is Woody engineered from scrap. I took the factory bumper shock and cut off both ends of the shock. I then welded the mounting bracket to what was left of the shock tube and then welded a clevis shackle to the tube.
I also decided to throw a quick $10 paint job on it. I liked the blue but there are areas that are not painted at the factory. I figured it would look less ugly if it was one color everywhere. Plus flat black adds 15 horsepower.
As you can see I painted everywhere and almost everything. Besides looks, the paint will protect items from the elements. Mostly the sun! You'd be amazed at how quickly the sun will destroy plastics and wiring on these cars. The brake reservoir turns to dust and the wiring gets brittle in only a few months. I also changed the radiator mounting up a little bit also. I wanted it off the bottom because I'm sure the front area will be get a little abuse.
Woody
