Old 12-13-2018, 09:08 AM   #23
BrantyB
Not sure what group you're planning to AutoX with, but check the rules because camber plates with PCA puts your car in a class you won't be competitive in. GT3 LCA's are great, but not close to free.
For autox I would suggest 18" wheels so that you can get the widest rear tire possible without losing sidewall stiffness. And you won't need to change sway bars. The car will have understeer, but I find that more useable than losing the back end. A lot will depend on how you drive the car.
RE-71's are terrific. You can flip the tires on the rim once the outer shoulder wears. I got over 100 runs from the fronts (50 before flipping). Rear outer shoulder is now spent, but I can flip and have enough tread for another season. The car has mild camber with 2*F/2.2*R because it sees a lot of commuter time too.
2022 PCA Zone 7 Autocross Chair
2001 Boxster 986 (base) #414
-PCA GGR: Class Champion AX12 '18, '19, '20; CC06 '21; CC05 '22; PAX 5th '19, 3rd '20, '21, & '22
-PCA Zone 7: Class Champion P14 '18, '19; P02 '20; P-03 '22; PAX Champion '20 & '21
BrantyB is offline   Reply With Quote
