Old 12-13-2018, 08:15 AM   #13
particlewave
Originally Posted by Traco View Post
Are you saying a nut like this in the pic below?
If so then how do you screw a splined stud into that? This is the 6 splined studs that I took out of mine and there was no evidence of any captive nut on the header
Yes, similar to that. It's been a while since I had mine off, but I believe two bolts on each side were splined studs and the third was a standard bolt with captive nut. A real PITA.
I replaced all of mine with SS bolts and nuts.
