Old 12-13-2018, 05:27 AM   #3
BFeller
Originally Posted by Blackroot View Post
Hello-
Im trying to prep for ims change and lock everything down.
I have a 3 chain motor, and have the pin in the pulley at TDC. The cam locking tool on bank 1-3(serpentine belt side passenger)will not fit.
The tool only goes one way, i know.
I turned the crank another 360 degrees and still no fit with the pin locked in.
There is a small notch on the pulley that lines with a mark on the case, and i was making sure that was aligned as well. It seems to just not fit in the top cam slot. Yes, they both look vertical. It seems that i can get the locking tool in if the tdc pulley mark is some 10 degrees atdc, but then the punch wont fit i to the pulley lock. Im stumped.
Yes, the cam tool is part of the ln pro kit and is the long one.
2004 boxster s special edition
Try toRotate the engine 180, not 360, then see if the cam tools line up. The notch on the cam is not on the center line of the cam.
"YouTube Certified in Various Specialties"
BFeller is online now   Reply With Quote
