Originally Posted by dachrist
Thanks for the suggestions guys. I can't re-use the nut, it is really rusted up in there so I do need to get it off. I will try the dremel cut off disc and see how it goes. The only issue I may have is access in there, its pretty tight...
If you have access to a Dremel (or other) multi-tool, it requires less space using a carbide blade.
