Old 12-10-2018, 04:42 AM   #20
rfuerst911sc
When you go to do the transmission hydraulic oil change make sure you remove the FILL plug first then the drain plug . That saves you the headache of having an empty trans with no way to fill it . And of the choices you have available I would go with the Castrol as long as it has the proper rating .
rfuerst911sc is online now   Reply With Quote
