Originally Posted by The Radium King
compression strength won't be much different than tension strength, hey? presume more than adequate for the application (threaded fasteners are designed for tension). i'd be more worried about the shear strength, however not much opportunity for a shear load in the application.
Once you have threaded that arm out 20mm for your -4 degrees of camber your presumption of adequate is just that.
I'll stick with something proven to stand up to the abuse we all dish out. A 20mm shim.
