Old 12-06-2018, 08:31 AM   #38
mwestboxster
In Cayman sizes (roughly 25.5-.6" diameter) there are hardly any tires that fit on the Cayman 17" wheels, 245/45/17 is one and 275/40/17 but the 275 is too wide for the oem wheel and barely anybody makes wider 17" wheels for Porsche fitments unless they are $$$. However plenty of good 18" wheels and lots of tires in those diameters. You could run 225/45/17 and 245/45/17?
On 986 Boxsters i have seen 255/40/17 square and I think 225/45/17 square on Hoosiers or hankook z214
Steved0x
Thanks for responding. Going with 18" wheels is no problem. I'd like to get as much tread to the ground that makes sense: It looks like from what I see posted that 255's work. Will a wider tread work/fit or is that sort of a diminishing return by possibly adding too much weight & resistance.
mwestboxster is offline   Reply With Quote
