Old 12-05-2018, 06:07 AM   #20
seningen
seningen's Avatar
M531 is an immobilizer unit without remote control function.
M534 and M535 do have additional remote control functions.
All of them use a transponder to activate the DME. There is no system that deactivates the immobilizer without transponder.
By the way - which DME version do you use?
Regards, Markus
5.5.2 99
I sent my DME/IMMOB/FOB to EcuDoctors -- they tested the setup and it worked fine.
I then had them modify the DME to be stand-alone.
My symptoms have not changed since I got it back. So as best I know the DME is fine and should be working in standalone mode.
So assuming the DME is working fine and the Immobilizer setup is happy -- what signals could prevent the DME from allowing the car to start?
I need to probe each one and see which is the cause?
I'm about this close to buying a second (cheap) Boxster just to have a known good unit to probe for signals on the DME.
thanks,
Mike
Drivers: '15 Panamera Hybrid (wife's), ' 01 996 GT2, 00 Boxster S, '96 993 Çab/Tip (wife's)
Race Cars: '75 911 RSR Replica & '99 Spec Boxster
mike@lonestarrpm.com
seningen is offline   Reply With Quote
