Another update with the most recent data from AMP with PCA this last Saturday.
It was a spectacular day to be at the track, great weather, air temp 65-70F, only a few cars in DE4, so a lot of open track!
Here's a link to the first 15 minutes of session 3, with data overlay showing the oil and accusump pressures. I had the by-pass switch turned ON for this session. This basically bypassed the pressure switch and kept the solenoid valve open.
https://youtu.be/-pKNVFNYCgE
Here's the updated data summary that includes the 4 sessions last Saturday:
Something went wrong for session 2 as indicated by negative pressures.
The oil pressure during session 3 was rock solid. I am sold on the Accusump by-pass mod. I think this is a configuration that can be used for pre-oiling as well as open valve for track usage. I also believe the 15 psi Accusump air side preload is more effective than the recommended 7-10 psi. One other thing I'm doing is keeping the oil level slightly above the max line on both the dip stick and the electronic gauge. No issues with AOS.
2002 Boxster S - NHP 200 Cell Headers,test pipes,Borla CatBack,Competition Plenum,74 mm TB, EVOMS Tune,Tarett UDP,Eibach Swaybars,BIlstein PSS9s,TuneRS rear toe links,wheel studs,15 mm wheel spacers on all 4,EBC yellow stuff pads,Sebro rotors, EBS oil baffles,160 deg Thermostat,2 quart Accusump,full filtration remote oil filter,rad fan switch,custom gauge/switch plate, Race Capture data logging, 90K miles
