Old 12-04-2018, 05:28 PM   #6
dghii
So be on the lookout!
Hard to shift may be an issue internal to the transmission (worst case $ wise). It could be hydraulics (clutch master, slav or both). Check the fluid level and look for leaks in front trunk. Slave cylinder is located on the left front side of the transmission (facing forward).
Motor mount may result in tough shifts and also presents itself (sometimes) with a resonate vibration around 3K RPM.
