Old 12-04-2018, 09:29 AM   #18
jaykay
jaykay's Avatar
Thank you; good information! I would think that a constant charge would kill your battery, but I can certainly see the advantages. I would have thought that the power to the aux port would die if the radio is switched off.....but then thinking about it the old CD changer is always live when you go to eject the magazine.
I think the ideal solution is to have a dash mounted switch to select charge or no charge; splicing a switch in the cable. Doing this with properly with a 986 momentary contact switch seems a bit messy....
How did you get it to wake and sleep via tap or gestures on the screen? I see no good option other than to jailbreak and and hack it.
986 00S
