Originally Posted by Smallblock454
Are the rims straight?
Are the tyres itself mounted correctly. Over here in Germany we have white dots on the tyres that indicate the balancing of the tyre itself. The white dot is supposed to be on the opposite side of the valve.
Are the brake disks worn? Sometimes bad brake disks lead to a wobble even if you don't use the brake.
Do you use wheel spacers? Remove them.
Regards, Markus
Hi Markus,
The rims are straight according to those who have balanced the tires - however, they have only been checked with the tires still on the rims.
I need to double check for the dot tomorrow, but this issue started with my old tires and has continued with my new ones as well.
Brake discs have a pretty bad lip on the edge and they squeal a lot. I do not get any juddering or anything when I hit the brakes though.
I do not have any wheel spacers.
