Old 12-02-2018, 05:21 PM   #9
Smallblock454
Are the rims straight?
Are the tyres itself mounted correctly. Over here in Germany we have white dots on the tyres that indicate the balancing of the tyre itself. The white dot is supposed to be on the opposite side of the valve.
Are the brake disks worn? Sometimes bad brake disks lead to a wobble even if you don't use the brake.
Do you use wheel spacers? Remove them.
Regards, Markus
Smallblock454 is online now   Reply With Quote
