I suppose I do have to run the RCA cables to the amplifier anyway so adding the wake up wire to go with it is not a big deal.
I WAS however planning on using the 12V+ constant on pin 4 of the black connector and pin 8 ground on the same connector for the new head unit. Everything else I would wire separate like the ACC power on and the like. I do have a question about pin 5 however for the antenna 12+. Do I need to supply power to this for my FM radio to get good signal? Is this a powered antenna? Is it hooked up to the same wake up wire I am going to run to my amp?
For future reference even though the CDR-23 didn't use them there were a few wires not accounted for and I found pin out for the black connector from this thread that accounts for them.
https://www.renntech.org/forums/topic/25829-becker-cdr-23-pinout-or-connector-wiring-diagram/
