Old 12-02-2018, 07:59 AM   #10
Boxstard
Originally Posted by Anker View Post
Porsche does specify that you should use no seize on the wheel bots and that you should be careful not to get any on the conical part that connects with the wheel.
Okay I was not aware of this... Somehow I though Porsche changed recommendation from lube to dry.
I lubed lug bolts for the last 3 decades with all other cars I owned and maintained, mainly Europeans incl. 914 and 3 generations of SAABs, with no issues. It is rather recentlly for the last 2 years of my Boxster ownership that I just clean bolts with a wire brush and dry-torque, assuming the 96 ft-lb spec based on dry especially as it seems relatively higher than typical 80 ft-lb spec. with other OEM's in my experience. I daily drive mine through MI winter and no corrosion issues when I change wheels/ tires twice a year.
Anyway I guess I'd go back to lube if that's what the P-doctor orders.
