Old 12-01-2018, 07:26 AM   #1
Boxstard
Nonsense. USING the proper lubricant will give you the most accurate torque readings.
It depends on how the torque spec was originally designed, with lube or dry.
For example, Porsche does not specify any lube on wheel lug bolts, so lube would cause actual torque above the spec.
