As long as people are talking about this topic, I thought I'd bring up an idea I had...
I'm betting most of us have seen those "Flex-Seal" commercials...
"We cut this boat in half..." "...even seals underwater..." etc...
I've thought of coating the outside of my tank with it. I'd put masking tape over the level window, and slather a thick coat of the stuff over the entire outside of the tank.
That way, there'd be no problem if the tank eventually cracked, even if it was at a seam or where the supports attach.
Before applying the Flex-Seal I'd wipe the outside of the tank down with a rag and some kind of solvent/cleaner (rubbing alcohol, whatever...) to remove any oily residue so that I'd have a good bonding surface.
Flex-Seal is basically rubber, so it should allow for some expansion/contraction of the tank (as it heats up and cools down) without de-bonding.
Again, just a thought...
If I ever end up doing this I'll post pics and/or a how-to...
(would probably have to be done BEFORE tank failure to provide the best bonding surfaces...)
thoughts?
2001 Boxster S - Speed Yellow, Black Leather, Tiptronic, Jake Raby rebuilt 3.2 with IMS Solution
