Old 11-28-2018, 01:01 AM   #17
Smallblock454
Ugly and loud might get me kicked out from events.
Ugly might not be a problem as long at it's safe.
As for the window frame. I'm definitely not putting a windshield back in it. I'm torn between cutting the frame off or keeping it. I do believe it adds some rigidity to the body but not enough to worry about. My biggest reason for keeping it is that I plan on jumping this thing and the rollover protecting might come in handy. That being said, I do think it would look cooler without it and will cut some weight. I'm still thinking about what I want to do. I'll be adding some reinforcement tubes for sure though.
The problem here is that the windscreen glass and the windscreen frame as constructive element add the rigidity. If you remove the glass you loose a lot of rigidity. You'll get the the best rigidity with windscreen frame, windscreen glass and sidewindows up. Without windscreen glass you'll get a lot more torsion in the front.
Reinforcement tubes can shurely help. But in the end this should be a kind of full cage (left to right and front to back) if you don't want to use a windscreen glass.
If you remove the door panels and the dashboard panel there will be enough room to do such a tube enforcement. But take care that there is enough space for yourself in case you have an accident and you don't can hurt yourself from how the reinforcement tubing is layed out (don't know if it's the right term – what i mean is where you put the tubing so it can't hurt you when there is an impact – so you have enough room for knees, elbows and so on) in the exterior. So safety always first. It can be ugly and loud as hell, but it has to be safe.
Regards from Germany,
Markus
