Old 11-27-2018, 10:48 PM   #1
Vza
99 boxster clutch
Hi, Doing my clutch and new DM flywheel on 99 boxster base.Few questions.
Torque for flywheel factory manual says 18 ft lbs + 90 degrees Bentley says 19+120 degrees think I'm gona go w factory manual..???
Torque for 3 bolts for throw out bearing guide tube Bentley has nothing factory manual says 26 ft lbs I went with this and used Loctite wicking threadlock
Factory manual says only grease input spline does anything else need to be greased in there??
thanks
Vza is offline   Reply With Quote
