Old 11-27-2018, 09:33 AM   #23
The Radium King
The Radium King's Avatar
cool. anyone know the difference between 986 and 987 front sways? otherwise, looks like you could put together an aftermarket m030 system w H&R springs, bilstein sport or koni fsd shocks, and used cayman rear sway. perhaps h&r front sway in a pinch (heavy though, and the h&r rear sway is too stiff unless you like a loose twitchy back end). total cost would be more than you could buy the actual m030 kit from suncoast, i bet.
edit to add: perhaps you could run a cayman front bar with aftermarket drop links? would still be less $ than running a gt3 bar ...
