Old 11-26-2018, 05:26 AM   #4645
Starter986
1998 Boxster Silver/Red
Saturday I reinstalled the oil pan. It was sooooo clean when it came down. Zero debris... zero sludge. I could have eaten off of it. I'll refill the oil, and check for leaks, after I install the S cooler later this week.
Installed the upgraded oil pressure relief valve. Breeze.
Yesterday I removed the thermostat and water pump. The WP removal I found to be a breeze... if not tedious. The hoses were a pain to remove... patience was key... don't want to break anything. The fins on the WP looked fine. Today I'll clean up the mating surfaces. Also, today I'll remove the motor mount and replace it with the new part. Time permitting I'll remove the throttle body and rubber intake parts.. clean them out... maybe just install that cooler today.
Maybe.
1998 Porsche Boxster
