This is my setup. I use a Mocal remote oil filter take-off plate, but with that set-up, I still needed the LNE Spin-on adapter.
TuneRS makes a really nice all-in-one take-off plate that does not require the LNE adapter and has a built-in check valve.
2002 Boxster S - NHP 200 Cell Headers,test pipes,Borla CatBack,Competition Plenum,74 mm TB, EVOMS Tune,Tarett UDP,Eibach Swaybars,BIlstein PSS9s,TuneRS rear toe links,wheel studs,15 mm wheel spacers on all 4,EBC yellow stuff pads,Sebro rotors, EBS oil baffles,160 deg Thermostat,2 quart Accusump,full filtration remote oil filter,rad fan switch,custom gauge/switch plate, Race Capture data logging, 90K miles
