Old 11-24-2018, 09:50 AM   #16
Oldcarguy
Oldcarguy's Avatar
Ok, I wanted to add a tip to all the good advise you already got..
If you cut off the head off 3-4 extra bolts (now studs..), you can use them to align the oil pan with the engine block during the final installation, this way you will not be making a mess with the sealant by moving the cover around.
If you cut a slot on the headless bolt (with a dremel tool), you can use a small flat screw driver to remove them from the engine and replace them with the correct bolt for final torque.
Hopefully my explanation makes sense, good luck!
It makes perfect sense. Awesome tip, thanks!
Rgds, Fred
Oldcarguy is online now   Reply With Quote
