Your alignment will be fine.
Its not great to have the car off the ground for a month, but you'll likely do no damage.
The coolant drain is on the bottom of the engine, no need to lower the rear. The car has like 6 gallons of coolant, so not getting a few liters out is no big deal.
i would however drop the front when you are filling to help with bleeding.
