Old 11-20-2018, 11:05 PM   #12
particlewave
Originally Posted by jaykay View Post
What is your preferred method of stripping it? I am almost considering a media blast of some sort....it comes off but...
I really haven't found any easy method, but plain water and a green scrub pad seems to work best on the loose stuff. I'll break down and use 1000 grit wet sanding for the more stubborn bits.
Chemicals are risky because a lot of the parts on his Volvo are ABS and will be damaged or even melted by chemicals (especially acetone...that will dissolve the plastic fairly quickly).
