Old 11-20-2018, 02:37 PM   #1
The Radium King
The Radium King's Avatar
gt3 lca and caster
anyone running an adjustable gt3 lca with a big shim say 15mm? what impact on caster? my rudimentary qeometry says that a 15mm shim in the lca means that the caster/thrust/track/trailing arm has to get 10mm longer to maintain same caster - is there enough adjustability in the eccentric thrust arm bushing to get a 10mm offset? thanks.
