Thread: Chain noise?
Old 11-20-2018, 09:44 AM   #19
jvfante
Santa Barbara, CA
Originally Posted by Boxstard View Post
Clutch in, noise gone.... I can not reproduce this noise not matter what rpm with the gear in neutral and car standing still. Only when car is running in gear, mostly in 3rd and 4th on the road, at steady speed with very delicate, slight throttle opening. Taking the foot off or pushing the pedal just a little instantly kills the noise, and back to the slight opening it comes back, very repeatable.
It seems as if combination of UDP, 996 TB and maybe 997 engine mount of recent changes is causing some kind of isolated system instability that the factory ironed out, and it woke up this noise ghost?
The clutch in making the noise go away seems to be pointing to your throw out bearing or perhaps a rattle/vibration in the release arm or spring.
As an aside, I had all sorts of fits with shifting in 1st gear making horrible vibrations until I replaced the single front engine mount. It's a cheap fix easily done in your garage.
'98 986 Arctic Silver
jvfante is offline   Reply With Quote
