More thoughts: All the warning lights are dead but the air bag light flashes for just a second when the key is turned on or off. My digital readings still light up as do the lights around (inside) the instruments but the clock starts at 12:00 each time you turn on the key and then keeps running till you shut off the key. The digital odometer displays the correct mileage and trip mileage but of course the digital speedo reads 0. If you replace the instrument cluster how do you set the correct mileage?
