Old 11-17-2018, 08:54 PM   #10
Geof3
Originally Posted by Qckslvr View Post
So after listening to some more sound clips and reviews of the FVD Brombacher Sound Version, I ordered one. Along with a used set of headers and test pipes.
Now the last set of questions I have.
Also should I wrap the headers and the test tubes with header wrap? Good or bad idea?
Bad. The M96 is somewhat notorious for spark plug tube leaks, and even cam cover leaks to some degree. That oil will pretty much drip right on top of a header pipe potentially, coating the wrap in oil over time. I was going to wrap mine until I researched it and saw a few videos of fires from just this sort of thing. Definitely need to wrap your PS line though, a burn through of that is a major fire hazard. Also helps keep an already hot PS system a little cooler to avoid spill over from your PS res.
