Old 11-17-2018, 09:30 AM   #15
Qckslvr
Qckslvr's Avatar
So after listening to some more sound clips and reviews of the FVD Brombacher Sound Version, I ordered one. Along with a used set of headers and test pipes.
Now the last set of questions I have.
Should I use a traditional header gasket or the OEM stamped metal gasket. I know from experience that early Fords would crack their manifolds or damage the head if you used a header gasket. It prevented proper heat transfer from the manifold to the head.
Also should I wrap the headers and the test tubes with header wrap? Good or bad idea?
I am keeping my fingers crossed that no bolts decided to break on removal. I am skilled at bolt removal.... but what a pain.
Also are the exhaust manifold bolts/studs 6mm or 8mm? Dave mentions 6mm, but other sites say 8mm. I would like to be prepared for my project.
Qckslvr is offline   Reply With Quote
