Old 11-15-2018, 06:03 PM   #1
JFP in PA
Originally Posted by truegearhead View Post
I’m on my second transmission and every track weekend at least once I can smell transmission fluid but I’m not leaking any (it’s burning off). Does anyone else have this problem? I’m wondering if a transmission cooler could help. Seems easy enough to install, is there any science to the pump setup?
The science is easy: Line out to the pump from the bottom drain plug, pump to an oil to air heat exchanger, line from exchanger to the oil fill plug. Biggest issue is where to mount the cooler.
