Originally Posted by particlewave
40psi it too high and lack of toe-in will make the front end feel loose and wander.
Should the toe-in be set all the way to max within spec? Or at 0? Should I drop the 29 psi listed on the fuel filler cap? Or do people usually run a bit higher/lower?
