Old 11-13-2018, 07:20 AM   #19
grc0456
2003 Base 5-speed
grc0456's Avatar
Originally Posted by CliffA View Post
i bought the '99' relay to have intermittent wipers on my '04 base Boxster....i found several relays located under the dash near the driver's left leg....which of these relays does the '99' relay replace?
thanks...
cliff
From the OP above:
"Installation is just removing the old wiper relay, which is in position #16 in the relay box under the dash above the fuse box (it's the single blue one to the right of the double convertible top relay on the second row from bottom), and inserting the new smaller VW one. It was a bit of a pain to remove the old one, but with a lot of yanking and swearing it finally just slides straight out."
