2007 Boxter S HID Conversion
... have a 2007 Boxter S ... recently converted my halogen headlights to HID ( Morimoto Elite kit- H7A, 6500k, 50W) ... main beam only .. look great, w/one small complaint ... notice a 'light' shadow in each beam center ... I'm guessing it's a result of the bulb base to top ignition wire running outside the bulb 'shadowing' the beams ... the bulb can only be inserted (keyed) with the wire facing upward, the upper side of bulb ... there was no option to select bulb with wire facing downward, below bulb ... any thoughts? comments? suggestions? Tx
