Old 11-10-2018, 08:55 AM   #16
Geof3
Well, I don't have an impact gun. However, when restoring my bim over a decade ago... same thing, bolt. I recall it being a breeze, but we'll see.
I'll loosen that bolt then start wiggling off the wheel, so it doesn't slam me in the face.
I'll be extremely patient and diligent with the entire process... as I want zero reason to have to buy anything else. I'll be very careful..
I'll pay extra attention when installing the new airbag... and will exercise caution when installing the torx screws. I'll position the bag... seat the torx screw to the bag... very slowly turn the screw counter clock-wise until I hear that little "click" then start screwing it in.
I do have a question for which I need some clarity... you said:
After removing the nut, put it back on a few turns and wiggle the wheel side to side.
With the airbag removed... I'll loosen the nut... pull the wheel until it is prepared to be completely removed (nut on so it doesn't hit my face when tugging)... remove the nut... and remove the wheel.
Your recommendation to remove the nut... put it back on... wiggle it from side to side. Do I perform that step as a precursor to removing the wheel? So I understand...
Remove airbag. Remove nut. Put nut back on. Wiggle wheel. Remove nut. Remove steering wheel.
Is that correct? Am I missing something?
I'll be returning this project later this morning.
Thank you.
Yeah, pull the nut first so you can take the wavy washer off. Then put the nut back on. You don't have to do that, but it gives you some more room when the wheel comes off. Also, with an impact gun the nut comes off fast, so I was really referring more to that...
