Old 11-10-2018, 04:59 AM   #7
Starter986
1998 Boxster Silver/Red
In the end, when you are finished, you will need to verify your levels several times, topping up each time before everything settles out.
Thank you. Yes. I will check it several times. I've read that the transmissions are sensitive to that.
Would you have a recommendation for a temperature gun... you know... point/aim and get the temp reading? Since I'll be using that tool very infrequently I'm not looking to spend a mint. Thank you.
1998 Porsche Boxster
