Old 11-09-2018, 10:55 AM   #1
Starter986
1998 Boxster Silver/Red
Steering wheel swap - Arghhhhhh.
OK. Battery disconnected. Key in on position. Waited an hour. Removed key.
Positioned the torx bit into a socket... connected to the ratchet.
The socket is too snug for the holes in the back of the steering wheel. I could get one torx screw loose, but the torx bit would be stuck in that hole.
What would you recommend I purchase to access those torx screws? And which sized torx end size? I see the Star Bit screwdriver set on Harbor Freight, but am concerned the screwdriver would be too long, and I wouldn't be able to line it up with the hole to access the depth.
What have you used to remove those torx screws?
Thank you.
1998 Porsche Boxster
