Old 11-07-2018, 11:53 AM   #6
Burg Boxster
Thank you. I guess I'd better get that in order (preemptively).
Well... since you are not having the issue at present... the BEST recommendation would be to simply reroute your emergency release cable to the tow hook area. Then in event of needing to use it you can just pop out the tow hook cover and pull the wire.
Good luck
"Cool Prius!"
- Nobody
